[Ja...] Posted June 19, 2018 Share Posted June 19, 2018 My CAD Model Disappeared after save Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/ Share on other sites More sharing options...
[Ma...] Posted June 21, 2018 Share Posted June 21, 2018 Go to CAD/ Modify CAD Entities and click on All Features visible and see if that brings back the model. Mark Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-99994 Share on other sites More sharing options...
[Ro...] Posted June 21, 2018 Share Posted June 21, 2018 This happens to me, and going to all surfaces visible doesn't help, clicking on the surface or wireframe button doesnt help, the only thing that "Brings Back" my model is to click on a profile (characteristic) that has a graphical output, for some reason that makes everything snap back into place. FYI i found that clicking on the button that automatically sizes the model to the screen size is POISON.nooooo.JPG Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-99996 Share on other sites More sharing options...
[De...] Posted June 21, 2018 Share Posted June 21, 2018 Have you tried redrawing the model? Go to CAD, View, Redraw Cad Model? Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-99998 Share on other sites More sharing options...
[b3...] Posted June 21, 2018 Share Posted June 21, 2018 Hi Jacquelynn, What is selected when you go to File > Cad Load Settings ? I had a similar issue in the past which changing this resolved. Laura Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100000 Share on other sites More sharing options...
[Ja...] Posted June 21, 2018 Author Share Posted June 21, 2018 This is what the settings are set to.CAD Settings.PNG Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100002 Share on other sites More sharing options...
[b3...] Posted June 21, 2018 Share Posted June 21, 2018 Weird. That's my settings and I'm having no issues. From what I recall, most of my issues with this came up in Calypso 2016. What version are you running, and which service pack are you on? You can see this on the home screen when you open the software or go to Help > About. Laura Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100004 Share on other sites More sharing options...
[No...] Posted June 22, 2018 Share Posted June 22, 2018 Are there still some files ending on *.sab and *.fct in the measurement plan folder? Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100006 Share on other sites More sharing options...
[Ra...] Posted June 22, 2018 Share Posted June 22, 2018 Please sign in to view this quote. What is the *.fct model for? Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100008 Share on other sites More sharing options...
[Ow...] Posted June 22, 2018 Share Posted June 22, 2018 Is it an actual imported cad model or just a wire frame created from feature recognition? Not sure what version you're running and it maybe a forgone conclusion but, if you've not worked with Calypso a lot, definitely try going thru the "show cad" buttons at the bottom. I remember certain versions of calypso being challenged with this and clicking thru each show tab eventually brought the model or wireframe back. Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100010 Share on other sites More sharing options...
[Za...] Posted June 22, 2018 Share Posted June 22, 2018 I have same problem then use Russian symbols in patch of measure plane. My Italian colleges if use national symbols for example è. Try change folder. Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100012 Share on other sites More sharing options...
[Ro...] Posted June 25, 2018 Share Posted June 25, 2018 Is there a way to attach a video to this thread? I captured the disappearance and reappearance of a cad model. Its about a minute long, probably less. Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100014 Share on other sites More sharing options...
[Me...] Posted June 25, 2018 Share Posted June 25, 2018 I have been having this same issue for some time now. Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100016 Share on other sites More sharing options...
[Te...] Posted June 28, 2018 Share Posted June 28, 2018 I saw this issue with Calypso 2015 with windows 10 haven't seen it since. I am not running Windows 10 so it could be a windows 10 bug. Everyone with this issue are you running windows 10? Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100018 Share on other sites More sharing options...
[No...] Posted June 29, 2018 Share Posted June 29, 2018 I have windows 10 on 3 machines and no issues at all. But there was a certain older Calypso version (which I don't remember) where the model could get "out of sight, meaning it somehow moved beyond the viewing plane ("outside of the screen" so to speak) and was only brought back by the "view all" button. Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100020 Share on other sites More sharing options...
[Ri...] Posted July 13, 2018 Share Posted July 13, 2018 There is a known bug when using SolidWorks models that will send your model out into another universe. I have had this happen where my model coordinates read in the Millions (Not a typo) of inches from CMM Home position. Please sign in to view this quote. My work around: 1. Select from the Tab Menu "CAD" 2. Select "CAD Model Control" 3. Select "Hide CAD View" 4. Close the program, click Save. 5. Reopen the program 6. Select from the Tab Menu "CAD" 7. Select "CAD Model Control" 8. Select "Hide CAD View" (Deselect) (It will have a check mark in front of it). Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100022 Share on other sites More sharing options...
[Gr...] Posted August 2, 2018 Share Posted August 2, 2018 I once had a problem with this. Turns out, somebody reorganized some of the folders with the inspection files. I undid that, and moved them all with Save As instead. Drag and drop or renaming in Windows File Explorer seems to cause problems. Everything else worked fine, I just could not get the visuals. Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100024 Share on other sites More sharing options...
[Ri...] Posted August 6, 2018 Share Posted August 6, 2018 I have this problem or a similar one, im guessing it is the same. The following quote is from Zeiss Please sign in to view this quote. This is how I remedy the disappearing CAD model. 1. Hide the CAD View 2. Save and Close the program 3. Re-open the program 4. UnHide the CAD View Occasionally, I have to toggle the model from wire frame to solid Once you start to see your model, DO NOT use the "Display all CAD features in the CAD view" button. EVER!CAD View Hide 1.jpg Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100026 Share on other sites More sharing options...
[Me...] Posted September 9, 2019 Share Posted September 9, 2019 I find the easiest thing that works for me is to heal the image. Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100028 Share on other sites More sharing options...
[Am...] Posted September 9, 2019 Share Posted September 9, 2019 I had this same problem last year, I eventually called Zeiss for help and they could not figure out what was going on. He created a new config file and everything was fine after that. He requested a copy of my original config file so they could look into what was happening but I never heard back from them about it. Link to comment https://qualityforum.zeiss.com/topic/17814-cad-models-disappeared-after-save/#findComment-100030 Share on other sites More sharing options...
