[Ad...] Posted September 6, 2019 Share Posted September 6, 2019 Hey Guys, I have a question I do a lot of FIA inspection and I work with parts that have multiple holes, diameters, positons, angles, etc. I would like to know what is the best way to get the Min and Max of these characteristics or actual measured diameters / dimensions. For example, I have a shaft that has 13 diameters with a range from .497 - .501. So I would measure it 13 times and have the report printout the results thirteen different sizes. But I just want to know how to get a function to printout the results with a Max and Min Range. Thanks, Adrian. Link to comment https://qualityforum.zeiss.com/topic/17822-min-and-max-question/ Share on other sites More sharing options...
[Ow...] Posted September 6, 2019 Share Posted September 6, 2019 If I'm understanding what you're wanting to do, the simple, maybe the most repeatable way, would be to use the 2-point diameter characteristic found under size, standards. Link to comment https://qualityforum.zeiss.com/topic/17822-min-and-max-question/#findComment-100074 Share on other sites More sharing options...
[Ad...] Posted September 6, 2019 Author Share Posted September 6, 2019 I meant to say is the diameter is 13 places. Link to comment https://qualityforum.zeiss.com/topic/17822-min-and-max-question/#findComment-100076 Share on other sites More sharing options...
[Me...] Posted September 6, 2019 Share Posted September 6, 2019 How about using Minimum and Maximum result under Size/More. You can choose multiple characteristics. You will need to create a characteristic for each item, but you can mask them and just report the Min/Max on your report. Link to comment https://qualityforum.zeiss.com/topic/17822-min-and-max-question/#findComment-100078 Share on other sites More sharing options...
