Navigator warning at startup
Having several measurement plans created (at another facility) on later versions of Calypso and now used on Calypso version 5.6.x, one recurring issue is this: several plans will warn that "The CMM does not support Navigator functionality ...". We must click through this message to continue loading the measurement plan. I have searched without finding the same issue in this forum. How is this message eliminated and the measurement plan modified to avoid its recurrence? This seems to be a sporadic problem and is obviously not relevant to every measurement plan in use. Thanks for any help you can offer.
When you create a measurement plan on a Calypso seat with an active Navigator license (default for offline seats), all scanning strategies have a number of checkmarks set by default, so speed etc. will be set to optimal values at each run. Which also means that no fixed values for these parameters are stored in the inspection file.
If you open such a plan on a seat without Navigator, you get this warning, which means that Calypso will use the default scanning parameters, possibly resulting in unwanted deviations.
To get rid of the message, either activate the Navigator license (if availabe) or edit all the scanning strategies and set fixed values. I'm not sure though if you can untick the Navigator checkmarks on a non-Navigator seat, so you may have to do the editing on a Navigator seat.
No, the CMM Calypso seats do not have Calypso licenses, hence the warning at startup. One local offline seat has a Navigator license.
