Gear Report
Hi everyone,
I would like to understand, and then explain to our customer, why are there these empty measurement areas in the report? Can You help me? these empty areas are correct?
Thank you in advance
I believe that is due to having outlier elimination and filtering both activated.
If you were to turn off filtering the outliers would be highlighted in the results.
