Polar/Cylindrical Coordinates
Here's something I always seem to have trouble working out. In the example below, let' say I want to report the width of the slot using a symmetry point. I add a pattern and I am able to get the 12 slot widths. However, I always get stuck when if I want to report the angle of each symmetry point relative to the center. If it were 12 circles in the pattern, I could just convert the coordinates of the circle from cartesian to polar/cylindrical, tick the Angle attribute of the feature and everything looks good. But if I do the same thing on the symmetry point, the angle/ radius and height values seem to be skewed relative to the symmetry point. And, the angle results are whacked, to say the least. If I do a best fit bore pattern of the 12 symmetry points, the polar angles work fine and that's all that really matters sometimes.
Can anyone explain how the polar/cylindrical coordinate system works when it comes to a symmetry point.
Also, what if you're using RDS-CAA and you want to measure this pattern of symmetry points with a stylus parallel to the top and perpendicular to the slots, A0 B-90, A30, B-90, A60 B-90, etc. Would I need PCM?
It's probably your projection axis.
Calypso tends to put features in strange axes.
Check the projection axis in the button where i (from i, j, k) is, and change it to the correct space axis.
In addition, you can recall your feature into an Angle Point. Features - Special Geometries - Angle Point. This will allow you to measure a feature to one alignment, but evaluate to another.
I believe this behavior has to do with the fact that a symmetry point has no direction, not even a point vector. In such situations Calypso often falls back to seemingly strange defaults. There's some inner logic behind it, but usually not the one you'd need.
The vector shown in the symmetry point is established by the first point. I don't think I have the option of changing this value without affecting the feature's strategy.
After converting to cylindrical values, it still shows I, J & K. However, changing the feature representation to Projected Angle, Space Axis is now visible. However, changing Space Axis to +Z, rotated the points the Z direction, as I expected.
After converting to cylindrical coordinates, select the button next to the i unit vector. This will allow you to set the reference for the projected angle.
