[Cl...] Posted August 21, 2019 Share Posted August 21, 2019 I have several O-inspects. I just noticed that one of them does not have the camera calibration program that utilizes the small glass slide, or I simply cannot find it. Where should this program be located? How often should I run this? Link to comment Share on other sites More sharing options...
[Br...] Posted August 21, 2019 Share Posted August 21, 2019 You really don't ever need to run that. Unless something got seriously messed up with your camera, that only needs to be done one time. I think when they calibrate it they might run it too. All you need to be running is the tactile/optical adjustment program. Link to comment Share on other sites More sharing options...
[Cl...] Posted August 21, 2019 Author Share Posted August 21, 2019 OK, thanks. Yes, I currently run the tactile/optical adjustment program weekly. Link to comment Share on other sites More sharing options...
[No...] Posted August 26, 2019 Share Posted August 26, 2019 Nevertheless, if you should ever need it: The most recent versions of tactile-optical adjustment and the glass template calibration are contained in a package of example measurement plans, which can be installed from the Calypso installer. It creates a folder named inspection_examples in \workarea. Inside it is a subfolder named 'inspections_optik' (yes, 'k' 😉 ) Link to comment Share on other sites More sharing options...
[Cl...] Posted August 26, 2019 Author Share Posted August 26, 2019 Thanks Norbert. Link to comment Share on other sites More sharing options...
