[Ca...] Posted August 12, 2019 Share Posted August 12, 2019 I've been asked to create whisker plots for some parts. I've never worked with whisker plots before, can Calypso generate them? Maybe in Pi-Web? Link to comment https://qualityforum.zeiss.com/topic/17936-whisker-plots/ Share on other sites More sharing options...
[Ri...] Posted August 12, 2019 Share Posted August 12, 2019 Yes, there is a Box Plot inside of PiWeb Reporting. You would need to create a report that adds this, but it is there. Link to comment https://qualityforum.zeiss.com/topic/17936-whisker-plots/#findComment-100744 Share on other sites More sharing options...
[To...] Posted August 21, 2019 Share Posted August 21, 2019 Link to comment https://qualityforum.zeiss.com/topic/17936-whisker-plots/#findComment-100746 Share on other sites More sharing options...
[Da...] Posted August 21, 2019 Share Posted August 21, 2019 Like Richard said, Piweb can do it but you'll be pulling your hair out trying to figure out how. If you know Python you can create these easily in Matplotlib. Whenever I need plots that are different from the default templates I do this instead of banging my head against the wall trying to understand Piweb. Maybe Piweb is easier than I make it out to be, I don't know. Link to comment https://qualityforum.zeiss.com/topic/17936-whisker-plots/#findComment-100748 Share on other sites More sharing options...
[Ow...] Posted August 22, 2019 Share Posted August 22, 2019 Please sign in to view this quote. Too funny 🤣 Link to comment https://qualityforum.zeiss.com/topic/17936-whisker-plots/#findComment-100750 Share on other sites More sharing options...
[Ri...] Posted August 22, 2019 Share Posted August 22, 2019 Please sign in to view this quote. PiWeb is a fairly user friendly piece of software. The only time it gets complicated is when you are adding custom variable statements. Link to comment https://qualityforum.zeiss.com/topic/17936-whisker-plots/#findComment-100752 Share on other sites More sharing options...
[15...] Posted August 23, 2019 Share Posted August 23, 2019 You can easily see a box plot by using the Group by function on a line plot, for example. In the side bar > No grouping > Group Data by > Measurement attribute So if I'm looking at a run chart of a certain characteristic, and I want to split by Machine #, or Cavity #, I would do that here. Link to comment https://qualityforum.zeiss.com/topic/17936-whisker-plots/#findComment-100754 Share on other sites More sharing options...
