What does this error mean?
I'm also having some issues with the measured values coming in with crazy numbers that are no where near the nominal. Any suggestions? **It should be noted that this is a scan of a minor diameter of a thread** 2084_43774a7ad2103241e6798a9ecfae4ec3.png
Can you view your actual measured points?
Usually when I get actuals that don't add up, its due to poor data collection (some features can be a pain)
Without seeing your program I'm going to guess that the results you're getting have something to do with your alignment of the feature. Not only are your actual x,y,z way out, but the angle of your feature is 90 degrees in both axis. Where does it show the feature at when you look at the actual points?
Robert
