profile
We will soon be making some parts that have profile called out for features that Calypso doesn't recognize from the solid model.
We are running Calypso 6.4 with curve.
Is it possible to get the feature from the SM? My thoughts were to "Generate Path", but without a feature how?
Any help is greatly appreciated!
https://qualityforum.zeiss.com/topic/17968-profile/
I think you have a few options. Both of which will be accessed by going to CAD>Creating features. First select the point set tab, set the feature as "Freeform Surface" and select the geometry on the cad to begin creating a freeform surface. The other way to do it is what I would suggest because I feel like I have a little more freedom of the shape of the actual measurement path. With the Creating features window open, select the "Section" tab. Here you can make slices in the geometry that can then be selected as 2D or 3D curves. You can always recall these curves into a freeform surface later to evaluate a Profile of Surface tolerance.
https://qualityforum.zeiss.com/topic/17968-profile/#findComment-100966
So that note has no datum references. What you could do, is do a bunch of 3D curves on all the surfaces that apply to that Drawing note. Then do a best fit of several curves alignment on all the measured curves. Then after that, do a profile of line on all your 3D curves referencing that best fit alignment. In the meantime, ask your boss if he'll buy you a license for Freeform.
https://qualityforum.zeiss.com/topic/17968-profile/#findComment-100994
IS it really irregular? It looks like its just on an angle, in which case regular profile of a plane would work.
If it is actually not a flat surface, then given that you do not have curve or freeform, then your best bet would probably be a series of space points over the entire surface and then evaluate them all to the same datum reference frame.
For the datum reference frame, I would create a geometry best fit alignment that includes all the points you create on the surface and allows full movement since the profile callout appears with no datum reference frame.
The alignment should best fit all the results as a set since they are all included in the alignment.
You can then use this alignment in your DRF setup for your profile callouts for the space points.
Then create a maximum and if desired a minimum characteristic that includes all your profile callouts you created for all the points. This will be your overall profile maximum / minimum result.
(wrote all this then saw the new licenses posted.. well .. this is still an option)
https://qualityforum.zeiss.com/topic/17968-profile/#findComment-100996
