[Cl...] Posted August 15, 2019 Share Posted August 15, 2019 543 O-inspect, as of late is frequently stopping mid program with "33 Collision" in the Status Window. Stylus isn't hitting anything but air. My first guess would be a dirty scale/reader head. Anyone else seen this? Link to comment https://qualityforum.zeiss.com/topic/17978-33-collision/ Share on other sites More sharing options...
[Ri...] Posted August 15, 2019 Share Posted August 15, 2019 Yeah. I would think of that, or you have heavy stylus system. Link to comment https://qualityforum.zeiss.com/topic/17978-33-collision/#findComment-101038 Share on other sites More sharing options...
[Cl...] Posted August 15, 2019 Author Share Posted August 15, 2019 Zeiss wrote the program, and designed the stylus system, which is just over the weight & length limit. But it has never done this before. I've brought up the weight and length issue before, and they say it's not a problem. I can't access the scales to see if they are dirty on an O-inspect as they are covered. Link to comment https://qualityforum.zeiss.com/topic/17978-33-collision/#findComment-101040 Share on other sites More sharing options...
[Ri...] Posted August 19, 2019 Share Posted August 19, 2019 Weight will always be the hard limit for any sensor. I don't know how far over it is, but I would think that long term usage would have adverse affects on the sensor. There are times where I've had to build stylus systems that go over length, but I tend to not worry so much if the weight is OK. If the weight is over, I try to not use that unless it is an emergency, and then I keep the usage limited. Link to comment https://qualityforum.zeiss.com/topic/17978-33-collision/#findComment-101042 Share on other sites More sharing options...
