[Za...] Posted August 15, 2019 Share Posted August 15, 2019 Hi colleges, some time ago i begun use self-centring point to measur littel gears (gear module 0,4) stylus with DK0.8. By my program operator measure a lot of parts and i sure that it have no mistakes. But we broke a lot of stylus during measuring this parts. Is it normal? It all this stylus sphere disconnect from shaft. Link to comment https://qualityforum.zeiss.com/topic/17982-self-centering-points/ Share on other sites More sharing options...
[He...] Posted August 18, 2019 Share Posted August 18, 2019 When doing self centering and the sphere "falls" of a surface it will travel much faster than the normal probing speed and that might break the small stylus. The speed depends on the probing force so try to reduce the probing force and see if it helps. Link to comment https://qualityforum.zeiss.com/topic/17982-self-centering-points/#findComment-101072 Share on other sites More sharing options...
[Za...] Posted August 19, 2019 Author Share Posted August 19, 2019 Can this affect the measurement result? Link to comment https://qualityforum.zeiss.com/topic/17982-self-centering-points/#findComment-101074 Share on other sites More sharing options...
[Lu...] Posted yesterday at 12:01 PM Share Posted yesterday at 12:01 PM I use a self-centering point to measure the external/internal diameter of the gear teeth. Also used for measuring bevel gear teeth. Link to comment https://qualityforum.zeiss.com/topic/17982-self-centering-points/#findComment-157376 Share on other sites More sharing options...
