Filtering a 2d curve
I have a new question regarding this post. I am recalling two 2d curves into a 3d curve. Each 2d curve length is different, so the wavelength settings for each will also be different. If I set the filter wavelength for the 2d curves before I recall them into the 3d curve, will those settings take effect in the 3d curve? Or If I need to set the filter wavelength in the final 3d curve? If so what value will cover each different 2d curve?
OK, but what about the wavelength setting for each 2d curve, how
can I set those in the 3d curve. There is only one setting allowed?
