Profile of Lobe _ Cylinder
Hello,
I am having difficulty with measuring a profile of a radius of an off set bore Datum C is the maximum diameter of the bore with three different lobes. When setting up the profile characteristic using ID and Datum D no result are presented with in the frame.
Thanks
Calypso really likes having a fully defined DRF.
Either use Free-Form and create an alignment using Best-Fit, or fill in Datum D as your Tertiary Datum. Datum C is Primary, Datum D is Secondary and Tertiary. It should work correctly then.
