CNC MODE POINTS ON A PLANE
Gentleman, i took 3 points for a plane and then 2 circle, made an alignment, then i took 40 points on same plane for flatness and then few features, i highlight all the features and go for CNC run, what i see is for 1st plane where i took only 3 points machine is taking many more points and not in order i took those points and finally it enters a hole to take a point, never saw this in any sodtware, i am new to Calypso, may be it is some setting some where, any help will be appreciated, thanks.
When you created the plane calypso may have auto generated a tool path based on your default settings.
Open the feature and click on strategy in the upper right corner.
The only thing that should be in there is "Clearance data" and your 3 points. Delete anything else.
