Thoughts on Sharing Alignment with multiple programs.
So as i've stated over & over, i almost always program parts in families.
Current project is no different and i get to thinking about doing something i've never had the guts to do before, give each program in a series the same alignment name.
The way we fixture the parts, the datum plane & line & point are always held in the same place regardless of how thick the part is, so what would be the cons of having 1 alignment for multiple programs?
Q to Steven & Owen.
So we have a dedicated place where we run all these parts, but if for some reason were to move the fixture, would doing an alignment on 1 part cause all parts to be updated?
FYI, all my alignments have features named exactly the same, Dat A plane, Dat B Line, Dat C point.
Yes,in my experience, the alignment as it is named and shared would update and you wouldn't have to do a manual alignment on each program to tell it where it is.
Just as Owen Said, One manual BA for all programs with the same BA Name.
Feature names and strategies are irrelevant, just as long at the x,y,z 0 is the same.
For example: we run a family of parts that share a BA, but we probe different areas (Features) depending on the Machining fixture locations.
