[Da...] Posted August 5, 2019 Share Posted August 5, 2019 Attached is a snip of a True Position callout that I feel would be better defined as profile but I am being asked to measure it as is. I'm not sure the Calypso software will facilitate this, and I need more coffee. Is this even a legitimate callout? It seems wrong to me, some insight would be much appreciated! Thanks! Link to comment https://qualityforum.zeiss.com/topic/18088-monday-fog-is-this-legit/ Share on other sites More sharing options...
[Me...] Posted August 5, 2019 Share Posted August 5, 2019 Looks legit. True position of a width to the centerline of -B-. It's a linear position in 1 axis +/-.0005. If the sides are planes you can create a symmetry plane from them and use that for your position. Robert Link to comment https://qualityforum.zeiss.com/topic/18088-monday-fog-is-this-legit/#findComment-101678 Share on other sites More sharing options...
[Da...] Posted August 5, 2019 Author Share Posted August 5, 2019 Thanks Robert, I'll give it a go. Link to comment https://qualityforum.zeiss.com/topic/18088-monday-fog-is-this-legit/#findComment-101680 Share on other sites More sharing options...
[Ro...] Posted August 6, 2019 Share Posted August 6, 2019 I agree with robert. Depending on your situation you could do this as a symmetry plane, Symmetry line, or Symmetry point. Either way make sure to select X only in your TP dropdown. Link to comment https://qualityforum.zeiss.com/topic/18088-monday-fog-is-this-legit/#findComment-101682 Share on other sites More sharing options...
