Monday Fog, Is This Legit?
Attached is a snip of a True Position callout that I feel would be better defined as profile but I am being asked to measure it as is. I'm not sure the Calypso software will facilitate this, and I need more coffee. Is this even a legitimate callout? It seems wrong to me, some insight would be much appreciated! Thanks!
Looks legit. True position of a width to the centerline of -B-. It's a linear position in 1 axis +/-.0005. If the sides are planes you can create a symmetry plane from them and use that for your position.
Robert
I agree with robert.
Depending on your situation you could do this as a symmetry plane, Symmetry line, or Symmetry point.
Either way make sure to select X only in your TP dropdown.
