Measuring angles
I´m having trouble to measure angles between different elements. I can report the angles of a single element, relative to the current alignment. But it`s not very convenient because i often have to make new alignments only to measure a single angle.
How do you handle this?
best regards
Rene
Have you used the "Angle Between Features" characteristic? If you use it on plane or line features, it returns the angle between them. If you use it with circle or point features, it returns the angle between them with the alignment origin as the center.
Thanks Michael and Owen,
that is exactly what i was looking for. I did not look for it in the form and location tab.
thanks a lot!
