Uploading CAD Files
I am having trouble uploading .stp & .pvz files.
I go to the CAD drop down bar and click load. Which then brings up the document explore box. The only options in the drop down menu to change the type of file it gives me is .sat files and a .* which finds everything else. This finds our .pvz and .stp files but they still wont load from this.
From the time of doing training at Zeiss. When I went into the same screen there it came up with lots of different file types and you would pick the suitable type.
Any help would be greatly appreciated. 🙂
You basically have to buy an add-on for everything but .stp I believe. When you went to training they had everything added on already. I have ACIS, STEP and DXF. If I ever get a model that isn't .sat or .step I just open it in solid works and save as .sat.
