[Jo...] Posted July 22, 2019 Share Posted July 22, 2019 I have a square part. Datum structure "Y" , "U" and "Z". Y being top, Z being right side and "U' being back side. This is how my base alignment is setup.YUZ. when I check true position using base alignment vs putting in each datum I get totally different answers. Which is correct? Link to comment https://qualityforum.zeiss.com/topic/18176-true-position-help/ Share on other sites More sharing options...
[Am...] Posted July 22, 2019 Share Posted July 22, 2019 Check your true position using the datums in order of how they are called out on the print. Link to comment https://qualityforum.zeiss.com/topic/18176-true-position-help/#findComment-102262 Share on other sites More sharing options...
[Jo...] Posted July 22, 2019 Author Share Posted July 22, 2019 that what I was doing. But shouldn't be the same since my base alignment is the same as the call out? It shows the locations being totally different looking at the feature vs the true postion location on the print out. Link to comment https://qualityforum.zeiss.com/topic/18176-true-position-help/#findComment-102264 Share on other sites More sharing options...
[Am...] Posted July 22, 2019 Share Posted July 22, 2019 When you are putting in the true position you have primary datum, secondary, tertiary and you can arrange them properly. In base alignment you are putting in the spatial and planar rotation. That might not match up to the way the datums are called out on the dimension. Link to comment https://qualityforum.zeiss.com/topic/18176-true-position-help/#findComment-102266 Share on other sites More sharing options...
[Ri...] Posted July 22, 2019 Share Posted July 22, 2019 Calypso follows the Can-May-Must rule. Most likely your Base Alignment isn't setup the same way as your DRF. If this is a Square Block: - Y would control Spatial Rotation, and Z origin (depends on orientation). - U would control Planar Rotation and Y origin (depends on orientation). - Z would control X origin (depends on orientation). Link to comment https://qualityforum.zeiss.com/topic/18176-true-position-help/#findComment-102268 Share on other sites More sharing options...
[Jo...] Posted July 22, 2019 Author Share Posted July 22, 2019 Thanks Richard, it was the planer that was throwing it off. Link to comment https://qualityforum.zeiss.com/topic/18176-true-position-help/#findComment-102270 Share on other sites More sharing options...
