[Mi...] Posted July 20, 2019 Share Posted July 20, 2019 Calypso 2018 v6.6.20. Windows 7 Enterprise Hi all, I have just upgraded to this version and one thing I found annoying is that I constantly get a Random popped up "Calypso Default Printout" whenever I click open a characteristic or a feature. How do I turn this off? Does anyone have this issue? Thanks in advance! Link to comment Share on other sites More sharing options...
[Mi...] Posted July 22, 2019 Share Posted July 22, 2019 The only way I have found to kill it off is as follows:: As you can see in the screen shot. Highlight the default report, then click the small screen in output to media section. I have them all X'd out. This will stop it from the current prg only. You will have to do this with all your programs. Its not a global change. I am running 6.6.16 so this may have gotten fixed in the new 2019 version but I am not sure,. Link to comment Share on other sites More sharing options...
[Mi...] Posted July 22, 2019 Share Posted July 22, 2019 If you do not see the default report in the printout features box, click the drop down under the NEW and add it then follow what I did... All this is under the Multiple Printout tab Link to comment Share on other sites More sharing options...
[Te...] Posted July 22, 2019 Share Posted July 22, 2019 The newer service packs, has at least pushed it to the back so it is not a annoying or bothersome as it was when 2018 launched. Link to comment Share on other sites More sharing options...
