[Da...] Posted July 15, 2019 Share Posted July 15, 2019 A while back , someone sent me a plan for running two cmm's from one network drive. I tried searching but, as usual, had no luck. Both machines have their own computers but the program files will be stored on a network drive. Anyone know how to do this? Link to comment Share on other sites More sharing options...
[Ri...] Posted July 15, 2019 Share Posted July 15, 2019 You just need to change your results and geoactuals folder locations. Extras - Settings - Environment - Paths - Change your files to be stored locally instead of with the measurement plan. Link to comment Share on other sites More sharing options...
[Da...] Posted July 15, 2019 Author Share Posted July 15, 2019 We are have trouble getting the default paths to stick in the correct place. It keeps trying to go the last file open instead of the main program directory. Link to comment Share on other sites More sharing options...
[Am...] Posted July 16, 2019 Share Posted July 16, 2019 We run 5 CMMs from the same drive without any issues. I have all programs in 1 folder named "Zeiss" on the drive and then one folder on the drive per zeiss that has the results. What sort of issues are you having? Could you put a screenshot of the paths window? Extras>Settings>Enviroment>Paths. Link to comment Share on other sites More sharing options...
[Br...] Posted July 16, 2019 Share Posted July 16, 2019 Go to Resources>Name for output files>for this measurement plan Or Resources>Name for output files>for all measurement plan If there's a list at the bottom under "All name definitions deviating from default", then that's where the file will save. Link to comment Share on other sites More sharing options...
