Running two cmms from programs on a network drive
A while back , someone sent me a plan for running two cmm's from one network drive. I tried searching but, as usual, had no luck. Both machines have their own computers but the program files will be stored on a network drive. Anyone know how to do this?
You just need to change your results and geoactuals folder locations.
Extras - Settings - Environment - Paths - Change your files to be stored locally instead of with the measurement plan.
We are have trouble getting the default paths to stick in the correct place. It keeps trying to go the last file open instead of the main program directory.
We run 5 CMMs from the same drive without any issues. I have all programs in 1 folder named "Zeiss" on the drive and then one folder on the drive per zeiss that has the results. What sort of issues are you having? Could you put a screenshot of the paths window? Extras>Settings>Enviroment>Paths.
Go to Resources>Name for output files>for this measurement plan
Or Resources>Name for output files>for all measurement plan
If there's a list at the bottom under "All name definitions deviating from default", then that's where the file will save.
