Mercedes Milling Test Block
Has anyone every had to measure a "Mercedes Milling Test Block"? Apparently, it is used for testing how fast and accurate 5 axis milling machines can cut this block. I've seen a picture of it being measured with a laser scanner but was curious if anyone has written a measurement plan for scanning with a Zeiss sensor.
Not sure if it has any affiliation with Mercedes or if it just implies that this is "the Mercedes" of milling test blocks.
Unfortunately, I only have access to a Prismo Ultra VAST. I'm guessing the Prismo is more accurate than Comet but it would certainly take a long, long time to collect an equal amount of data. My plan is to measure "select' areas of the block just to validate we're on the right track. Customer has their own laser scanner which will be used to qualify the quality of the machining.
Owen, you are correct but this block was designed for 5 axis machining test.
