How to prevent probe hit to part then broken?
Defect part like missing hole , when program move to inside hole but no hole.
Is there some function in software or some patch?
You could try going into Feature Settings Editor - Travel - Speed & change the speed down to 5 or 10 on the features that potentially cause crashes, like small holes. It won’t stop the crash but it should prevent broken bits 🙂
There a special function for this:
In the feature, go to projection => Missing bore and turn it on.
You also can set this fast in the feature settings editor under Probing section.
