File renaming in Excel reporting
Hello all,
Has anyone tried to change the way of naming an excel file? In default, the excel file is called "name of the measurement plan" + "part number" and I would need to add to the name field "date" and other check boxes depending on the fields given at the CNC start. I am using the standard file "Characteristic.xlt" and "ReportINI". I tried to change the macros in these files, but there is no file response - the name is still the same. Can someone have a solution to this problem? Maybe anyone have a solution to this problem?
https://qualityforum.zeiss.com/topic/18314-file-renaming-in-excel-reporting/
I have the same issue. I can not rename the excel file trough macro change.
I'm thinking to try to save "TXT" file with "name for output files" so you can rename the file as you want, then create an Excel Macro that copy name and contents in new Excel File.
This is just on my mind. I didn't do that yet but i hope is an help for all of us. 😉
