THERMOPLATIC PPS MEASURING
Hello,
i will have to measure thermoplastic pps material with our CMM ACCURA II with VAST head.
There is some trick about strategy, kind of probes, measuring forces, etc..?
I checked on Calypso Manual but i haven't see anything.
Thanks
We measure only plastic parts, but not PPS. Judging by what I found on the net, there's no siginificant difference regarding measurements. Zeiss has almost nothing about plastic measurements, not even a cookbook.
If you're experienced in measuring plastic parts, I recommend you use the same startegies, probes etc
If you're not experienced, then no forum thread can teach you that. Maybe you want to ask a more specific question, otherwise I could write a novel ๐Ÿ˜‰
Hello,
We also process PPS material and have this constantly at the CCM.
This material belongs to the group of high-temperature materials and is very dimensionally stable and hard.
You don't need any special strategies to measure!
In any case, I would advise you to create a form plot when measuring diameters, so you get a graphical balance of the possible shape deviation, depending on how your component is constructed!
I don't have experience about plastic measurements so i explain to you what i want to know:
-Can i use the rubin probes or we need to buy an other kind of probe material?
-Can i use the same strategy which explain on metals Cookbook (for example Scanning mode, speed, nยฐof points)?
-Can i use the same measuring force which use with metals measurements?
I hope is enough ๐Ÿ˜ƒ
1) you can use ruby ball
2.) Strategy is the same as for metal
3.) Measuring force Standard, depends on the probe!
long and thin probes = less force
ร—
ร—
