printout
I just started using the PiWeb reporting and we have a template for our company but when I run a program it does not print out after each cnc run. I get a pop up window of the template and then I have to manual print it out. What am I doing wrong. I attached some screen shots. I think I have everything checked off. Thanks in advance
piweb2Doc1.pdf
What version of Calypso? What Service Pack?
Everything appears to be set correctly. Though I've had similar issues in the past.
FYI - The print checkbox in the Plots row of the Run window only applies to plots you've enabled to print.
Hi Tom, We just upgraded to 6.6 (05.06.2018) Do you think the Text box would have anything to do with it, where you can type information in.
Thanks
Tom, called zeiss support today, there is a glitch with version 6.6 to printout results using PiWeb. You have to go to settings and environment and set your printer to a specific printer and then it will work. The tech. said he will report it. Thanks
  • 8 months later...
