Add Note to Result see attached
I don't think you can add it directly to the characteristic as you show. You can add a Text Element either before or after the feature and add a description.
Robert
Inside the Characteristic just click on Comment. Type in the lower portion of the comment section, the top part is the name of the characteristic. Whatever you type there will be shown in the area you have as an example.
Mark
