[St...] Posted June 17, 2019 Share Posted June 17, 2019 Using Calypso 2015 Is there a way to have characteristic values (X, Y & Z) be reported as absolute values Thanks Steve Link to comment Share on other sites More sharing options...
[Da...] Posted June 17, 2019 Share Posted June 17, 2019 You could use a "Result Element" characteristic and use the abs function in a formula. abs(getActual("Origin").x)Capture.PNG Link to comment Share on other sites More sharing options...
[Mi...] Posted June 17, 2019 Share Posted June 17, 2019 As an alternative to Dave's suggestion, you can also define a secondary alignment using the same features as the base alignment, but with two axes reversed, then define the features with respect to this. Link to comment Share on other sites More sharing options...
[St...] Posted June 18, 2019 Author Share Posted June 18, 2019 Thanks for the replies, I'll go with Dave's suggestion. You would think that would be an option, the tolerances get a little confusing with negative values Steve Link to comment Share on other sites More sharing options...
