[Da...] Posted May 27, 2019 Share Posted May 27, 2019 Hi, is this a legal callout? Should I report one hole or both?cy.pdfcy.zip Link to comment Share on other sites More sharing options...
[An...] Posted May 28, 2019 Share Posted May 28, 2019 See attached.Contribution_28_05_2019.pdf Link to comment Share on other sites More sharing options...
[Aa...] Posted May 28, 2019 Share Posted May 28, 2019 I don't know that it's illegal. If it were me, I think I would do a best fit bore pattern. I'm surprised they didn't want to use datum A. Link to comment Share on other sites More sharing options...
[Er...] Posted May 28, 2019 Share Posted May 28, 2019 Not going to help you now, but if I recall correct, a function for this is comming in 6.8. (Two parallel common datum's) Link to comment Share on other sites More sharing options...
[Br...] Posted May 28, 2019 Share Posted May 28, 2019 No It's drawn incorrectly. Position can only be applied to features of size, not a basic dimension like that. I think it's obvious though the intent is to control the holes to the pattern. They could've done something like 2x Ø[diameter size], and applied the position tolerance to that pattern with no datum reference frame. I would interpret it like that and report the position of both features to the pattern. Link to comment Share on other sites More sharing options...
[Da...] Posted June 13, 2019 Author Share Posted June 13, 2019 Thank you all for replys. I went with this approach:tp1.PNGtp2.PNG Link to comment Share on other sites More sharing options...
[Da...] Posted June 13, 2019 Author Share Posted June 13, 2019 I could try bore pattern, if I'd have the knowledge. I'd still need to pick that symmetry as primary datum, right? And I have no idea what to do with checkboxes "rotation" and "translation"tp3.PNG Link to comment Share on other sites More sharing options...
[An...] Posted June 13, 2019 Share Posted June 13, 2019 Try four intersection points. See attached.Contribution_13_06_2019.pdf Link to comment Share on other sites More sharing options...
