[To...] Posted December 7, 2018 Share Posted December 7, 2018 I have tried searching this forum and google for a solution but without luck. I am having a datum that is four cylinders. How can I combine them as a single feature so I am able to choose them as my datum. Link to comment Share on other sites More sharing options...
[To...] Posted December 7, 2018 Share Posted December 7, 2018 Resources, Utilities, Geometry Best Fit Alignment Link to comment Share on other sites More sharing options...
[To...] Posted December 7, 2018 Author Share Posted December 7, 2018 Please sign in to view this quote. Thanks for the quick answer, but it doesn't get me all the way. As the datum is supposed to be my tertiary datum for a true position of a plane I am not able to choose it. How could I do that? Link to comment Share on other sites More sharing options...
[Me...] Posted December 7, 2018 Share Posted December 7, 2018 One way... Create True Position of the cylinders as a bore pattern constraining the correct DOF to your Primary and Secondary datums, for example rotation only, and use the alignment created from the pattern as your datum structure for TP of the plane. Link to comment Share on other sites More sharing options...
[To...] Posted December 7, 2018 Share Posted December 7, 2018 Robert is on the right track Link to comment Share on other sites More sharing options...
[To...] Posted December 7, 2018 Author Share Posted December 7, 2018 Please sign in to view this quote. Think I have figured out now. Created hole pattern with the Primary and secondary Datums. Then create a new True position and choose Datum Reference frame -> Alignment "Bestfit1" . When I do so there will only be a primary datum? But this primary datum will be the same as the previous datums but include the hole pattern as Tertiary datum? Link to comment Share on other sites More sharing options...
[Da...] Posted December 7, 2018 Share Posted December 7, 2018 Tommi can you show us the drawing (without dimensions)? Link to comment Share on other sites More sharing options...
[Öz...] Posted December 10, 2018 Share Posted December 10, 2018 Hello Tommi; I hope, i understand your question well. And at the attachment you can find my way to measure your question. Hope it will helps.4 cylinders.zip Link to comment Share on other sites More sharing options...
[Da...] Posted December 10, 2018 Share Posted December 10, 2018 Hi Özgür, what interface/app should we use to open .mht files? Some google chrome extension? I've tried -> https://chrome.google.com/webstore/detail/eml-mht-viewer-with-drive/ahbjckdnggnfmchoildeljnilenlkoao/related?utm_source=chrome-app-launcher-info-dialog but it only works for files under 10MB. Link to comment Share on other sites More sharing options...
[Öz...] Posted December 11, 2018 Share Posted December 11, 2018 Hi Dane; I just use chrome. No extension. I dont know why you cant open. Can you try it with internet explorer? Link to comment Share on other sites More sharing options...
[Da...] Posted December 11, 2018 Share Posted December 11, 2018 It works with Internet Explorer ver. 11, but doesn't work with Chrome ver. 71.0.3578.80 OK, thanks Link to comment Share on other sites More sharing options...
[Da...] Posted December 11, 2018 Share Posted December 11, 2018 Please sign in to view this quote. Thank you for this, I will try something similar hopefully soon. Sorry if I missed the slide, but where does the intersections come from? Link to comment Share on other sites More sharing options...
[Öz...] Posted December 11, 2018 Share Posted December 11, 2018 Actually i have to say sorry. I start step recording after creating intersection points. So they didn't come nowhere. I made them before. Link to comment Share on other sites More sharing options...
[Ja...] Posted December 12, 2018 Share Posted December 12, 2018 Ozgur, thanks for the tip on the Problem Step Recorder. I didn’t know that existed. If I understand the OPs’ problem correctly (please correct me if I’m wrong), I have the exact same problem. I have a datum reference frame with a primary and secondary datum, with the third being a bolt pattern. The best fit method that Ozgur did such a nice job of showing covers the bolt pattern, however it doesn’t account for the primary and secondary datums. I believe there are a couple of ways to integrate them. The first way would be to refer to them using the Select References button in the Best Fit. For the callout I’m working on, this method doesn’t allow me to associate the primary datum, only the secondary. So what I did was to make a secondary alignment using the primary and secondary datums only (eliminating as many DOF as possible) and referring to that alignment in the Best Fit alignment instead of the default base alignment. Now all three datums would be accounted for. Is that acceptable? One thing to keep in mind though – you won’t receive any bonus tolerance on any of the datums listed in the datum reference frame (if applicable). You’ll have to use a result element to add any bonus. Link to comment Share on other sites More sharing options...
[Da...] Posted June 12, 2019 Share Posted June 12, 2019 Please sign in to view this quote. Tommi, are you using "3d Best Fit Alignment" or "Geometry Best Fit"? Link to comment Share on other sites More sharing options...
