[Mo...] Posted April 21, 2021 Share Posted April 21, 2021 I'm trying to automate a scanning & inspection template and when the scanning first starts, I sometimes get this pop-up dialog (see photo). One has to hit "OK" and then the scanning begins. Recording these actions in the script editor does not result in any code, so I'm wondering if anyone knows how to write a line of code that hits "OK" on this dialog box. Alternatively, does anyone know how to get rid of this pop-up box altogether? Link to comment Share on other sites More sharing options...
[An...] Posted April 22, 2021 Share Posted April 22, 2021 Hello Monica, maybe a web thermometer like the "Web-Thermometer Pt100/Pt1000" from W&T would solve your problem with the temperature...!? https://www.wut.de/e-5760w-10-inde-000.php With a device like that the ATOS software can read the temperature by ifself and nobody has to type in the temperature manually. Link to comment Share on other sites More sharing options...
[Ma...] Posted April 22, 2021 Share Posted April 22, 2021 Hello. You can set a Temperature and ATOS will never ask you again before you start a measuring. Go to Edit > Preferences > Hardware > Temperature and set a fix room temperature. We got the same problem as you and we've found the settings few days ago ? Link to comment Share on other sites More sharing options...
[Mo...] Posted April 22, 2021 Author Share Posted April 22, 2021 AH thank you. I tried to look for a settings feature and missed this one! Link to comment Share on other sites More sharing options...
