[Me...] Posted June 3, 2019 Share Posted June 3, 2019 While measuring a hole feature with a regular VAST head, fixed probe the CMM just stopped and told me that it had done so because flyscan option was not available. I programmed this hole like any other that it had already scanned, but for some reason this error came up on this particular hole. As far as the hole is concerned, simple drilled hole, not threads, spot face or anything other than a machined cylinder in some aluminum. Any ideas why I'm getting this error? Link to comment Share on other sites More sharing options...
[c3...] Posted June 3, 2019 Share Posted June 3, 2019 Perhaps did you select FlyScan in your strategy by accident? It would be under the Special Settings in your strategy window. Link to comment Share on other sites More sharing options...
[No...] Posted June 4, 2019 Share Posted June 4, 2019 Have you possibly programmed this partly on an offline seat? I had similar issues with Navigator errors in programs created on an offline seat. The solution was to deactivate the Navigator option in Planner. Link to comment Share on other sites More sharing options...
