I have 6 IDs...
I got 6 ids to check the offset of each one to each other.
Cant figure out how to do it.... See cut through on the attachment.
I do not have PCM, and I have tried to do it with formulas but cant get it to work. Im sure I am missing something on this bright sunshiny Monday morning...
It seems like what is required here is that all the bores are within a maximum given distance in relation to one another.
I would suggest you use an avg feature construction, then give a distance to that from each of the others with your +/ 0.02 tolerance.
If they are also called out in relation to other datum features, you probably would want an alignment to that/those datum feature(s) and use that in your average feature construction.
The average should give you a position in the middle of all the features, your distance characteristics can give you the variation from the average location. If you include a maximum and minimum characteristic, you could provide the maximum and minimum amount of error from the mean.
So if i understand the drawing correctly, there is a overall distance and tolerance, but each cylinder must be within .002 of each other.
You could group these circles into a min and Max feature and do a cartesian distance between the high& low.
