[Me...] Posted March 14, 2019 Share Posted March 14, 2019 Hi guys i have a problem with extracting a feature from a CAD. What i am doing wrong ?? Do i need some Licence for Calypso or a n extra measurement module? 20190314_083655.pngFetching info... Link to comment Share on other sites More sharing options...
[Da...] Posted March 14, 2019 Share Posted March 14, 2019 Did you try auto healing? healing1.JPGFetching info... healing.JPGFetching info... Link to comment Share on other sites More sharing options...
[Me...] Posted March 14, 2019 Author Share Posted March 14, 2019 i will try it now , thanks ! Link to comment Share on other sites More sharing options...
[No...] Posted March 14, 2019 Share Posted March 14, 2019 It would be helpful to know what kind of geometry you're trying to extract. Depending on whether you display the CAD in wireframe or in solid mode Calypso can be very picky about which type of geometry you can select. Link to comment Share on other sites More sharing options...
[se...] Posted March 14, 2019 Share Posted March 14, 2019 As Norbert mentions..... and I have been barked at more than once.... about clicking while attempting to create curves. Giving it a second try and carefully clicking the needed 'wires' has made the 'Invalid geometry' watchdog go away. Link to comment Share on other sites More sharing options...
[Me...] Posted March 15, 2019 Author Share Posted March 15, 2019 still the same message Invalid geometry, i think it must be a free form feature/surface Link to comment Share on other sites More sharing options...
[No...] Posted March 15, 2019 Share Posted March 15, 2019 To pick a surface feature, you must display the model in solid (shaded) mode. Link to comment Share on other sites More sharing options...
[Me...] Posted March 21, 2019 Author Share Posted March 21, 2019 i did this to 😭 Link to comment Share on other sites More sharing options...
[No...] Posted March 21, 2019 Share Posted March 21, 2019 And it still doesn't work? Then I can only imagine two reasons: - you selected a feature type in the toolbar that isn't compatible with the surface clicked (example: you can't extract a circle from a flat plane) - something's (still) wrong with your CAD model. Link to comment Share on other sites More sharing options...
[Me...] Posted March 26, 2019 Author Share Posted March 26, 2019 i am trying to measure this profile marked with red but i do not have the curve module. what is the best way to measure this profile? 20190326_093819 xc.pngFetching info... Link to comment Share on other sites More sharing options...
[Cl...] Posted March 26, 2019 Share Posted March 26, 2019 Do you have free from surface? If not you can use space points all over the surface and use the Space Point Distance for each point, applying +/-.05 tol. Link to comment Share on other sites More sharing options...
[Me...] Posted March 26, 2019 Author Share Posted March 26, 2019 Sometimes you have to sneak around the part to find a spot to pick. I've had this on cylinders and planes. I've had to pick on the inside of cylinders then tell it it's an outsider. same with planes. Link to comment Share on other sites More sharing options...
[Te...] Posted March 29, 2019 Share Posted March 29, 2019 Normally if you get that error message it means it is a free form surface and not a 3D feature Calypso can extract like a Plane, Cone, Cylinder, Sphere Link to comment Share on other sites More sharing options...
[Ch...] Posted May 29, 2019 Share Posted May 29, 2019 Typically what I do for these sort of features is create an unknown contour, then as stated in a previous reply create a bunch of space points and obtain a profile that way. There are work arounds if you don't have the fancy FreeForm or Curve modules, it just takes longer to perform and process your results. Link to comment Share on other sites More sharing options...
[Da...] Posted May 31, 2019 Share Posted May 31, 2019 Looks like an Unhealed torus...will calypso accept that ? Link to comment Share on other sites More sharing options...
