[Ja...] Posted May 30, 2019 Share Posted May 30, 2019 We use run parameters at the start of each job so we can put part serial #, inspector #, job #, etc in the printout header data. I am setting up an autorun template for inspectors to run at system start without using Calypso as has been mentioned in a recent thread. Is there any way to automatically trigger the measurement plan definition upon running program (similar to pressing run in Calypso)? They'll forget to right-click, Define Run Parameters every time (or press CNC). Thank you. Link to comment Share on other sites More sharing options...
[Ja...] Posted May 30, 2019 Author Share Posted May 30, 2019 Nevermind, I found it. In case anyone is wondering; Open the program in Calypso (not Autorun) -> [Resources] -> [Printout Header Parameters...] -> Check "Force Input at Start" Now I will need to do this to a lot of programs... Link to comment Share on other sites More sharing options...
