True Position Datum
This is just taking multiple datum features and combining them as a single datum feature. This is mostly used to take two coaxial cylindrical datum features to combine them and create a single feature axis, or Co-planar Datum features, and treat them as a single plane. Sounds like you have the later but I can't see it on the picture you provided. If you have two planar datum features, just simply treat it as a single plane. In Calypso, you can either measure both in a single strategy with two different paths, or you can measure them as separate features and recall feature points into one single plane. If they aren't co-planar, it gets trickier.
https://qualityforum.zeiss.com/topic/18552-true-position-datum/#findComment-104414
Those datum features aren't co-planar. I cant really make much of sense out of it. Part of me thinks they just want Datum B to be the secondary. It's hard to tell what the intent here is.
Larry, Is there a basic dimension defining the angle of the two planes from one another?
https://qualityforum.zeiss.com/topic/18552-true-position-datum/#findComment-104422
Even if you considered D-B as a mathematically defined surface, point cloud, whatever, D still does nothing as a co-datum because it's already constrained as the primary. It's can't go anywhere. Check it as D-B-C and call it a day.
It's hard to tell if D and B are perpendicular to each other from the image. If they aren't then I would surmise they did the co-datum because they didn't realize/understand you can have a secondary datum that isn't perpendicular to the primary and thought they needed to use both of them.
https://qualityforum.zeiss.com/topic/18552-true-position-datum/#findComment-104424
I'm sorry I have not responded before now. I got very busy and didn't have time to look at the responses after my last post...Andreas is correct in that B and D are NOT perpendicular to each other. My thoughts were that the intersection between B and D would be the D-B call out, but from what I am hearing, B will be the secondary datum for this True Position.
D-B Print.pdf
https://qualityforum.zeiss.com/topic/18552-true-position-datum/#findComment-104428
