Keyboard Shortcut for Views
Is there any way to use the keyboard to snap to different view orientations? Like the "View From +Z" etc. menu at the bottom of the CAD View? I use these a lot, and moving to the mouse is a little annoying.
Resources>Function Call
I THINK this will let you make your own shortcuts.
Never tried it and Im not at a machine to look at it either. But again I THINK you can make ur own but I am not 100% sure....
Like Mike stated Resources/ Function Call or hit F12
When you hit F12 a dialog will come up and ask to active the numbers. Select Yes, you will do this one time. Now open the number chart file. Next you will be prompted to enter a number to make a function call. Type 0 for the list.
The number to save a view is 315. Just type that in the box and hit enter and the Save View dialog appears. Give it a name and your done. Repeat for each view and you just enter 315 no need to type 0 because you know the number you need.
Mark
Back on the old forum, there was a section where you make suggestions and other users could vote on them. Then, Zeiss would incorporate some of the changes in future versions. I feel like having the option to view from the basic +Z, -Z, etc. views, from a secondary alignment would be a huuuuuuge improvement. Granted you can view from a saved view but that requires a bit more work.
