Changing Alignment
Yes, you can change your alignments but which alignment are you changing?
  • You can add additional alignments
  • You can change your base alignments but you must take care here because you will be prompted to change the nominals to the new alignment which you need to do but you must also go back and verify the nominals.
You must not move your CAD model orientation, if using one, once the base alignment is setup. You must make the model changes through the alignment routine.
Mark
