Secondary Alignment
Trying to practice writing some programs using Calypso, still new at it. I can't figure out how to make a secondary alignment. I have set up my base alignment on my fixture but would like to make a secondary alignment on my part inside the fixture. How do you accomplish this?
If you use secondary alignments a lot, actually anything you use frequently, you can go to the view menu and select the toolbar editor and add the alignment option to the toolbar for quick access.
Anything you leave blank in the secondary alignment will default back to the base alignment. So for instance you can select a circle for your new X & Y but if your Z and rotation and level aren't changing you can leave those features empty.
