[Me...] Posted May 18, 2019 Share Posted May 18, 2019 Goodnight You could help me I am looking for the way that in CHR file certain information is kept like: Cavity Number: Date and Time: Mold Number: Operator number: That would be all I need at the moment I hope you can orientate me Link to comment https://qualityforum.zeiss.com/topic/18580-how-to-save-information-in-chr/ Share on other sites More sharing options...
[Me...] Posted May 20, 2019 Author Share Posted May 20, 2019 I have this code but I still can not save it in the CHR. question where can I find the address of the format Calypso uses to generate the CHRtest4.pngtest5.png Link to comment https://qualityforum.zeiss.com/topic/18580-how-to-save-information-in-chr/#findComment-104576 Share on other sites More sharing options...
[Ro...] Posted May 20, 2019 Share Posted May 20, 2019 Ill take a look at it tomorrow, i've never used chr files before so im not sure if calypso will create one. I see you are using the extension ".PARA" in your add to file code. I have code very similar to yours for a text file, but i like to set my directory path as a variable. filePath = "X:\Org\CMM\REPORTS\XXX\WSPC_REPORTS\Part_Number-xxx\"+getRecordHead ("planid")+"\" ext = ".txt" N1 = getRecordHead ("planid") N2 = getRecordHead ("lotid") deleteFile(filePath + N1 + (" ") + N2 + (" ") + ext) //delete duplicate file dirPath = filePath + N1 + (" ") + N2 + (" ") + ext //#11 DIM11 = getActual("# 11 Dat C Distance").actual //#12 DIM12 = getActual("# 12 Perpendicularity").actual //#21 profile DIM21 = getActual("# 21 Profile").actual DIM21MAX = getMaxActual("# 21 Profile Min Max").actual/25.4 DIM21MIN = getMinActual("# 21 Profile Min Max").actual/25.4 addToFile(dirPath,(" ")) addToFile(dirPath,N2) addToFile(dirPath,N1) addToFile(dirPath,date()+ (" ") +time()) addToFile(dirPath,(" ")) addToFile(dirPath,("Dim 11 Distance : "),DIM11) addToFile(dirPath,("Dim 12 Perpendicularity : "),DIM12) addToFile(dirPath,("Dim 21 Profile : "),DIM21) addToFile(dirPath,("Dim 21 Min/Max : "),DIM21MIN," / ",DIM21MAX)Capture984654.JPG Link to comment https://qualityforum.zeiss.com/topic/18580-how-to-save-information-in-chr/#findComment-104578 Share on other sites More sharing options...
[Me...] Posted May 20, 2019 Author Share Posted May 20, 2019 Roberto thanks your code helps me to complete the one I have. but I have a question of chance you will know the route of calypso for the CHR format. Link to comment https://qualityforum.zeiss.com/topic/18580-how-to-save-information-in-chr/#findComment-104580 Share on other sites More sharing options...
[Ro...] Posted May 21, 2019 Share Posted May 21, 2019 Did you try changing the extension from TXT or PARA to CHR? I was able to create a CHR report but since i don't have anything to open it with i don't know if its a legit file. Link to comment https://qualityforum.zeiss.com/topic/18580-how-to-save-information-in-chr/#findComment-104582 Share on other sites More sharing options...
