O-INSPECT placing features in wrong place.
Hi I have a program thats been driving me crazy. I don't have much luck with the O-inspect program working correctly except for basically when its created. For example I ran a part today and the line scans are finding the points in the correct place but putting the actual line quite a distance from the points. Was repeatable the day I made the program and if I crate a new feature today on that program it matches the line up perfectly but if I run a feature that was created last time it finds the points just fine but places the line off from where the points are.
I don't have any new pics but here is a pic from when I ran into this the first time. What am I doing wrong and can I still fix this program without redoing everything its a pain to make it over again its quite lengthy. Do I need to run the calibration again? Do i need to change something about the feature or edge analysis? Any help would be greatly appreciated.
The Yellow Line is the nominal scanning line. That is where it is supposed to be. Your points are picking up the actual location of the line.
Then I don't understand why my result is so far off where if I create brand new features they are dead on nominal. But thank you I'll have to look into it and see something else must be going on.
Another question I have is on another program I have a feature that moves a bit from part to part and when it looks for it it will be just off from the area its scanning, is there something i can do when it comes to the feature where the program will stop and allow me to manually move where the search area is? That would work a lot better if I could make it work. Thank you for your help, im very new to the o-inspect.
