[Je...] Posted May 16, 2019 Share Posted May 16, 2019 Is there a relatively easy way to combine two different reports into one in Calypso? I have a pair of mirrored parts that have different programs but are all on the same print as an assembly. I would like to compile all the results from the two programs into one report after the run. I am running 2018 (6.6.15) but am using a custom printout, haven't taken the PiWeb dive yet. Link to comment Share on other sites More sharing options...
[No...] Posted May 17, 2019 Share Posted May 17, 2019 This should be possible with a measurement plan macro. No PCM stuff, just a second plan used as a macro in the first one. I don't remember the exact process, since I needed it only one or two times, but the help file should have a description. Link to comment Share on other sites More sharing options...
[Je...] Posted May 17, 2019 Author Share Posted May 17, 2019 Thanks, I'll look into that option. I don't use macros often so it will be a learning experience all the way around. Link to comment Share on other sites More sharing options...
