Probe won't connect
Hello
I was wondering if anyone would know why I have 1 probe setup that will not connect when I do an auto pickup from the probe rack. I have 4 probe setups and all the other are fine. I even used it earlier today when I went to pick it up again it would not connect to the rollers and I got an error message.
Thank you
What was the error message? The two most common problems (VAST) are:
- probe doesn't connect to all 3 rollers (error will say so) --> clean rollers
- IDE chip PCB doesn't make proper contact with the two spring-loaded pins in the head --> clean pins and pads on PCB with alcohol. If pads are already corroded (small dark dot visible in center of pads) clean with a glass fibre pen.
