[Pa...] Posted May 10, 2019 Share Posted May 10, 2019 I'm having tough time getting perpendicularity measurements to read in tolerance, specifically cylinder to plane. Modus within the machining cell shows good, but Calypso regularly reads out. Bench confirms Modus. I'm thinking we giving calypso too much data (typically 1000s of points) and inevitably a few points fall out of the envelope. I have spread out the cylinder and plane as far as realistically possible to get a true representation of the feature and avoid projection error. Any ideas? Maybe just use 4 point cylinder and planes? Outliers and Filters are on, Evaluation is LSQ. PaulSchuyler Link to comment https://qualityforum.zeiss.com/topic/18644-perpendicularity-strategies/ Share on other sites More sharing options...
[Da...] Posted May 10, 2019 Share Posted May 10, 2019 So the plane is the datum? How are you doing this on the bench? If you flip datums then you will probably get different readings. Link to comment https://qualityforum.zeiss.com/topic/18644-perpendicularity-strategies/#findComment-105002 Share on other sites More sharing options...
[Ri...] Posted May 10, 2019 Share Posted May 10, 2019 Ditto to what Dave said. In addition, 1000s of points is going to be much more accurate and repeatable when constructing a cylinder. It is using those to construct an axis line. A few "bad" points isn't going to throw off an LSQ axis line. This is also why we use things like Outlier Elimination. Thanks. Link to comment https://qualityforum.zeiss.com/topic/18644-perpendicularity-strategies/#findComment-105004 Share on other sites More sharing options...
[De...] Posted May 10, 2019 Share Posted May 10, 2019 The feature being checked should be using a minimum feature evaluation because perpendicular is a zone tolerance. Not sure if it will help or not but it can't hurt. Link to comment https://qualityforum.zeiss.com/topic/18644-perpendicularity-strategies/#findComment-105006 Share on other sites More sharing options...
[Ro...] Posted May 11, 2019 Share Posted May 11, 2019 Ive had a problem when using Helix Scan in the past for perpendicular check. I found calypso likes 2 circles with 400º sweeps high and low, and you can put a helix 2 or 3 revolutions in between if you want. Link to comment https://qualityforum.zeiss.com/topic/18644-perpendicularity-strategies/#findComment-105008 Share on other sites More sharing options...
