[Ha...] Posted April 23, 2019 Share Posted April 23, 2019 Has anyone had any issues with results in Piweb loading extremely slow? We have PiWeb SBS and currently only save/use results from 4 different programs. We have a fair amount of data saved, but we have only been using Piweb for 4-5 months now. I really cant imagine we already have enough data that would slow down our software. I'm assuming I'm saving our results wrong because there's no reason it should be this slow. Any thoughts? Link to comment https://qualityforum.zeiss.com/topic/18650-piweb-results-loading-very-slow/ Share on other sites More sharing options...
[Ri...] Posted April 25, 2019 Share Posted April 25, 2019 Have been complaining since we started using PiWeb. PiWeb adds up to 2 mins to a cycle time sometimes. Link to comment https://qualityforum.zeiss.com/topic/18650-piweb-results-loading-very-slow/#findComment-105024 Share on other sites More sharing options...
[Ma...] Posted April 26, 2019 Share Posted April 26, 2019 Hallo Jungs, hatten ein ähnliches Problem. Habe dann mit dem Support gesprochen, die Erklärung war das mit den Verbindungsparameter was nicht stimmte. Zuerst die Verbindung prüfen(max-URI Länge)siehe Bild. Danach die qdb-configuration anschauen oder editieren. ❗ Den genauen Wert kann ich euch leider nicht sagen. ❗ ❗ Sorry PiWeb ist auf "Deutsch" 🤣 Bitte mit Support Rücksprache halten. 🙄qdb-configuration.pngmax-URI-Länge.png Link to comment https://qualityforum.zeiss.com/topic/18650-piweb-results-loading-very-slow/#findComment-105026 Share on other sites More sharing options...
[Ri...] Posted May 10, 2019 Share Posted May 10, 2019 Try leaving the PiWeb Report open at the end of the run. Then, the software doesn't have to restart. Seems to help a little. Link to comment https://qualityforum.zeiss.com/topic/18650-piweb-results-loading-very-slow/#findComment-105028 Share on other sites More sharing options...
