Excel\results output directory
I've updated Calypso from 6.4 to 6.6, the previous CMM operator had a lateral install of 6.4 and 6.0 with 2 sets of inspections, results, etc. I'm trying to clean everything up with this 6.6 install everything under "C:\Users\Public\Documents\Zeiss\CALYPSO". one issue I'm having is the excel output going into ~Zeiss\Calypso 6.4\workarea\results instead of ~Zeiss\Calypso\workarea\results. I'm certain I've overlooked the obvious in the help section, but I can't locate it....even if I rename the 6.4 folder, the excel output goes ahead and makes a new Calypso 6.4 directory.
tl;dr version: where can I change the default output directory for results?
Yup, that did it, thank you. I had to restart Calypso to change the default, running it in administrator mode to get the changes to stick.
