Variables to save
Hi
I use the custom report.
I use more than two header variable to save the files to PDF.
In PIWEB you can?
I have the PIWEB BASIC and want to know if it is possible.
Thank you
It works with the same way as for the "old" reports.
Inside the example the path, date and time are assigned with PCM, the incremental part number by report header fields.
Today in the personalized report I can separate by folders like sector, year and month.
I thought PIWEB would work, too.
Thanks you
Not sure if this is your answer, but I have mine set up to use single and double header variables.
After you select the DIRECTORY, then click the PRINTOUT HEADER FIELDS. Double click which ever variable you want the PDF saved out as. I assume you can have as many as you want.
Then click the file ending to drop in a .pdf on the end.
Program will save under the folder and variables you chose.
I think this is what you want to do no???
