Variables to save
Not sure if this is your answer, but I have mine set up to use single and double header variables.
After you select the DIRECTORY, then click the PRINTOUT HEADER FIELDS. Double click which ever variable you want the PDF saved out as. I assume you can have as many as you want.
Then click the file ending to drop in a .pdf on the end.
Program will save under the folder and variables you chose.
I think this is what you want to do no???
https://qualityforum.zeiss.com/topic/18668-variables-to-save/#findComment-105104
